Hi guys,
Ran into another issue and 99% sure I am missing something very basic.
When I try to run daylight (annual / factor) simulation, I get the error mentioned in the subject. Below is the full readme data:
- Annual climate-based analysis
- The component is checking ad, as, ar and aa values. This is just to make sure that the results are accurate enough.
- Good to go!
- Current working directory is set to: c:\ladybug\unnamed\annualSimulation\
- Runtime error (MissingMemberException): ‘NoneType’ object has no attribute ‘X’
Traceback:
line 3207, in testPtsStr, “”
line 1990, in writeTestPtFile, “”
line 197, in main, “”
line 253, in script
AAV_GH_R4.gh (832.2 KB)
Edit: Also can you help me understand why the glazing added isn’t internalized in the GH file? Unless I open the model on Rhino, I don’t see the glazing/skylight. Once I load the model with the GH file I can see the glazing.
Edit 2: Ok so i atleast figured out the problem is related to the glazing as mentioned in the first edit. I am also attaching the .3dm file which I used to place the glazing in the right area.
AAVRhino.3dm (544.4 KB)
