Hi everybody,
When I try to bake the Ladybug_ Bar Chart and Line Chart component the errors occurs as below.
Anyone faces this before?
Bar Chart read me: Current document units is in Meters
Conversion to Meters will be applied = 1.000
The layer name: 'ISTANBUL - TUR IWEC Data ’ is not a valid layer name.
Runtime error (TypeErrorException): ‘NoneType’ object is not iterable
Traceback:
line 1183, in main, “”
line 1203, in script
Line Chart read me: The layer name: 'ISTANBUL - TUR IWEC Data ’ is not a valid layer name.
Traceback:
line 469, in bakeGeo, “”
For Bar Chart: basic inputs comes from Read Ep results comp. such as…
read ep results (all results) > energy balance > select average data > Bar chart. (also added image: before and after baking)
For line chart: 3 basic inputs
import epw (dry bulb temp.) > Adaptive comfort calc
read Ep results (air temp + mean rad. temp.) > Adaptive comfort calc.
Hi @mostapha. I also face the same baking problem as @kalpkirmaz, when working on monthly energy balance data.
You can see attached a simple file with the problem.
FYI, when I try to bake it using the native GH commend I get the error that “You are about to bake an invalid mesh.”
Sorry @devang. I don’t know why the data is internalized like this.
Please see attached the full model. The relevant components are in lower right side of the canvas. AB_FT_BaselineEnergyModel.gh (807.3 KB)
Thanks @devang. It mostly solved the problem.
Just as reference for others, of course the quotations must be made all non-curly.
More importantly, there are still minor problems to perhaps think about later. One is that the legend mesh is not backed. Secondly, an input of 2 to bakeIt crashes it again.
Thanks @devang for the offer. But I cannot make it to internalise the data correctly. While first they the Data content looks fine, strangely, after restarting Rhino the dates are replaced with those keys.
