I am trying to run daylight analysis using the 1.2.0 version of LB Tools and when i run the annual daylight part I get this error “1. Solution exception:Result folder contains no grids_info.json.”
You get that error because the simulation didn’t run correctly. Looking at your screenshot, that Wea component is not like the others. I suggest you manually replace it.
also is it not possible to attach non-planar surfaces as glazing? i have a building thats oval in shape, i have split it into straight segments and did the same for the glazing i want to attach to it. but when I add it as a subface i get this error: “1. The following sub-faces were not matched with any parent Face:
Aperture_725130e6”
This error was just a generic on that you get whenever the recipe fails
I implemented a much better error reporting system in the latest development version of the plugin. So, if you upgrade to that with the “LB Versioner”, you’ll get a more detailed report of the real error.
