1. Solution exception:'ScheduleFixedInterval' object has no attribute 'default_day_schedule'
Hello
I created a schedule by FixedIntervalSchedule for set points and made a program. Then, I wanted to use DeconstrProgram, but I encountered an error message.
Mohammad
Hey @Mohammad.hakim.a ,
That component is meant to deconstruct schedules that are composed of repeating day schedules.
FixedInterval Schedules are not structured this way since they’re composed of a full list of 8760 values. I imagine the component that you actually want is the HB Schedule to Data component, which can give you all 8760 values of your schedule as a data collection.
I’ll see if I can implement a better warning message in that component so that people don’t get confused about this in the future.
FYI, I added a better warning message on the component:
Hi @chris
Your answer is ideally. This warning message got better.
