1. Solution exception:'str' object has no attribute 'points'
Hello, I would like to run a artificial lighting simulation. When I inser IES fcomoponent I got this error called “1. Solution exception:‘str’ object has no attribute 'points”.
If anyone help me with that problem, I would be really glad.
Thank you in advance.
@pelinavci ,
try connecting your list item directly from the ouput and not through a panel.
It still gives the same error
sorry I just noticed this that might be the issue?
Yes, that’s the problem, how come I didn’t realize that, thank you very much…
