Hi
is it possible to set skylight on the wall and define it as a roof to the zone? I mean if I do this,
is there any possibility to case mistake on the result?
by the way, the building surrounding is connected to the eastern side of the building. is it better to set it as a zone and separate it from result or just set it as context?
Thank, N.z
Hi,@nasrollah
For Q1: It is very hard to set skylight on the wall and define it as a roof to the zone. I suggest you use add glazing compotent.
For Q2: For my experience, I prefer to set it as context because the setting is easy.
If I set it as glazing then it would be open during natural ventilation time. because I’m working on nature ventilation. so any suggestion?
again thank a lot.
