Thank you @sarith
Here is the files written by HB+ before run, from the example file: test_room.zip (782.8 KB)
Regarding multiple executions; yes I know what you mean if you are refering to 5PM HB+ implementation .
However that doesn’t seem to be what is going on:
-Look at this copy of the commandprompt from an execution of the 5PM 5PMcommandPrompt.txt (27.0 KB) (seems to me that it is repeating)
-Simulation times are way higher than usually.
