8760 visualisation from Incident radiation...How do I do that?
Sorry for bothering you…Just figured it out….LB Time Interval Operation is the magic key and will give me the monthly productions
Hello @charlie.brooker,
thank you for putting together the script; it’s very helpful. I’m encountering an issue with the grid size: I only get one point per surface, and reducing the grid size doesn’t increase the number of points unless I set it to less than 100. Even then, I don’t get the expected 8760 values per building—instead, I end up with more. Do you have any suggestions for how I might resolve this? Thank you!
Hi @soukyj,
I’ve received the script you sent me, but the geometry isn’t internalised so unfortunately can’t check exactly what’s going on.
Also, the script you shared uses another grasshopper library I don’t have installed.
I’m a bit confused what your end goal is, if you could share some more details that could be useful.
Cheers,
Charlie
Thank you for your reply. My objective is to obtain the hourly solar irradiance for each facade of the building to evaluate the potential for BIPV. Using a grid size of 1000 results in only a single data point at the center of each building, which doesn’t accurately reflect the solar irradiance across the entire surface. When I reduce the grid size to 10, I end up with hourly irradiance values for each grid point instead of each facade. I’m looking for a way to find a balance: using a smaller grid size for better accuracy while still consolidating the data to reflect the hourly irradiance for each facade. I attached the file with internalized the data. Thank you for taking the time to have a look at it!
hourlyAuto-name-Buildings+surfaces_autosave_autosave.gh (136.7 KB)
