A new componet for Honeybee Object Search Tool for Grasshopper
Hi everyone,
I’m excited to share a small plugin designed to help us quickly search for Honeybee objects . This functionality existed in the legacy OpenStudio for SketchUp plugin, and I’ve basically recreated it for the current workflow. Interestingly, this Python plugin, named HB Search Model , was crafted with the help of AI vibe coding.
It is a powerful model retrieval component aimed at helping users efficiently locate and filter objects within complex Honeybee models using keywords.
:hammer_and_wrench: Core Features
1. Multi-Level Deep Search The tool traverses the Honeybee model comprehensively. It supports searching not only for Rooms but also dives deep into sub-objects including:
  • Faces
  • Apertures (Windows/Openings)
  • Doors
  • Shades (Both interior and exterior)
Beyond the hierarchical structure, it can also identify and retrieve Orphaned Objects (independent faces or apertures not assigned to any parent).
2. Flexible Matching Logic
  • Multiple Keywords: Supports inputting multiple words separated by spaces. The search uses “AND” logic (i.e., the object must contain all keywords).
  • Wildcard Search: Supports * (matches any number of characters) and ? (matches a single character) for fuzzy searching.
  • Case-Insensitive: The search process automatically ignores letter casing.
3. Precise Filtering Control
  • Object Type Filter: You can specify only certain object types via the _obj_type_ input (e.g., search only Rooms or only Shades).
  • Search Field Limitation: Allows users to choose to match only the name (unique identifier), display_name , or both.
4. Detailed Data Output
  • matched_objs : Outputs references to the matched Honeybee objects.
  • matched_names : Outputs the display names or IDs of the corresponding objects.
  • matched_types : Clearly identifies the object type for each match (e.g., Room, Face, etc.).
  • count : Real-time statistics of the total number of matched objects.
:light_bulb: Use Cases
  • Quick Positioning: Rapidly find specific functional rooms in large energy simulation or daylight analysis models.
  • Batch Extraction: Bulk retrieve objects based on naming conventions (e.g., extract all windows containing both “Office” and “South” in their names).
  • Model Checking: Verify model naming standards or check the distribution of specific shading components via keyword search.
  • Workflow Automation: Serve as an upstream component in Grasshopper definitions to provide a filtered list of objects for subsequent operations (such as modifying materials or assigning properties).
    Here is a screenshot and a demo file.
honeybee search model demo 02-25.gh (91.5 KB)
HB Search Model! that 's nice!
Thanks your feedback
