Hello everyone! I use LB Direct Sun Hours 1.8 for my solar analysis in Rhino7. There was no error on the front battery, and the LB Direct Sun Hours battery pack turned yellow when it was last run and showed 1. Input parameter _run failed to collect data!, and I can’t show the insolation analysis (shown in the picture below) What is the reason for this, and I would appreciate it if you could help answer your questions!
Your Toggle that is assigned to _run is disabled in the grasshopper canvas.
note: you should not assign the same geometry as geometry and as context.
