Hello all. I’m running Annual daylighting recipes to return DL metrics. I’d like to use same results to drive lighting control, but want to be realistic - two sensor points, maybe 4, rather than the dozens I’ve defined for the room analysis. Is it possible to pick sensor points (from the simulation) when using the ‘HB Daylight Control Schedule’ component? or do I need to run a 2nd ‘Annual Daylight’ simulation, with a different grid defined?
Hi @NickNovelli,
That is not an option right now. You have to run a simulation with a different grid.
Mikkel, thanks for your attention. I surmised as much after poking around a bit more, and added a second simulation (that runs when I run the EM components).
