Hi everyone.
I’m studying gridbase simulation using example data (http://hydrashare.github.io/hydra/viewer?owner=mostaphaRoudsari&…;).
it’s runs comfortable.
In the result data(.res file) , There are three result .
could you tell what each data express?
Honeybee_Grid-based_Daylight_Simulation_Example_II.gh (495 KB)
Cgrashoppergridtest_0.res (26.2 KB)
The results are irradiance values for red, blue and green for each test point. Read this thread on Radiance mailing list: http://www.radiance-online.org:82/pipermail/radiance-general/2015-J…
Hi, Mostapha.
Thank you your reply.
When I change simulation type to radiation(wh/m2) , do the results means red,blue and green range radiation?
when I use visualize the results(recolormesh), I think the value is same as first data.
I thank you for reading it through.
