About the LB Generate Point Grid
Hello!
I Generate Sensor Grid from the floors of Room, The floors become an undulating surface.
What should I do to solve this problem?
And everything else is normal.
Hi @Ultra
You have two options
  1. Set the input quad_only_ to True but you may miss few points from acute corners.
  2. Try either Sensor Grid or HB sensor Grid from Rooms components.
