Because the radiance in honeybee can simulate the number of reflections and determine the surface material, I choose to use radiance to simulate large-scale urban radiation, but there is a problem
I identify the volume as honeybee_surface, but it only simulates one surface
Because in the new version, it will be more troublesome to recognize these faces as honeybeemodel, so I have to use the old version.
Hi @123songhaodong, I would be happy to help but your question is not clear at all. Are you asking for a solution to visualize the face inside Rhino/Grasshopper? There are several components that allow you to visualize the geometry.
I want to use Radiance to calculate the radiation of the building surface at the urban scale, but when I connect the city block, it only calculates the radiation of one surface, not the other surfaces, so I want to ask how do you do it. Thanks so much
It looks like you are using Honeybee[+], which is mostly deprecated at this point. I suggest installing LBT 1.4 from Food4Rhino and using that instead. You will see the installation instructions here:
