I am using the Accelerad software, and although I manually input the RADparameters, the output from the Daylight Simulation readMe! conflicts with the _ad parameter (I input 32 and it reads 1000).
Any ideas why this is?
Thanks
this is “forced” by the runDaylightAnalysis component in cases where your ambient values are not set “well enough”. I don’t think it is related to accelerad. If you use “higher accuracy” inputs, you 'll notice that they will be used unchanged.
