Accelerating multiple "HB point-in-time grid-based" simulations
Dear scientific Ladybug community,
within my research on switchable membrane cushion constructions I need the so-called incidence operator of the facade for different angles of incidence. (You can find more about the RadiCal methodology in the dissertation by Daniel Rüdisser https://www.radi-cal.org/)
Here’s my gh script:
main.gh (90.5 KB)
Compared to a simulation with the “HB Annual Daylight”, no sky matrices based on real weather data at a specific location are required. In a broader sense, multiple “HB point-in-time grid-based” simulations are carried out. The sensor brightnesses are simulated for different incidence angle pairs, in my case 1000 randomly selected pairs over the hemisphere, with a defined direct normal radiation without diffuse horizontal radiation. Without diffuse horizontal radiation and with a slope facing up (slope=0), there is also no ground diffuse radiation active.
However, my current Grasshopper script requires between 3 and 24 hours, depending on the radiance accuracy to calculate the 1000 incidence angle pairs. I am of the opinion that a reduction to 5-10 minutes is possible by creating a quasi-“HB Annual Daylight” simulation with own “weather data” and by merging certain work steps.
Do you know how to solve that problem? We would also support the programming of a Grasshopper plugin financially. I would be very happy about your help or quotations.
Kind regards
Simon Weber, M.Sc.
Research Associate
Institute for Acoustics and Building Physics
Pfaffenwaldring 7
70569 Stuttgart
Germany
E-Mail: simon.weber@iabp.uni-stuttgart.de
this was solved with the help of @sarith. Thanks for that. It’s part of the sampling step within the incidence operator method. More details in our publication: https://www.researchgate.net/publication/395416022_A_parametric_design_integrated_sampling_and_general_training_approach_for_optimal_control_oriented_surrogate_models_of_light-related_quantities
Feel free to contact, in case you have the same problem.
Kind regards
Simon Weber, M.Sc .
Research Associat e
Institute for Acoustics and Building Physi cs
Pfaffenwaldring 7
70569 Stuttgart
Germany
Tel: +49 711 685 66301
Website: http://www.iabp.uni-stutt gart .de
https://orcid.org/0000-0002-6 268- 8547
