Hello!
Is it possible to export/access the OpenFoam (Dicts, Schemes, Solutions, Properties, etc.) files? I have access to OpenFoam on our computational physics cluster so I was hoping to be able to set up the geometry, and the meshing/boundary conditions in Butterfly then upload the files to the cluster to run larger simulations using SimpleFoam. Is this possible to do with Butterfly? Thank you for your time!
Hi,@bourcetj The answer is yes. You can use blockMesh snappyHexMesh and solution component to write OpenFOAM file. Then you can use command to run openFOAM on your computational physics cluster.
