nano
December 21, 2023, 6:28pm
1
Hi!
I am simulating heating and cooling loads.
However, I would like time series data on the results.
zsz of HB Model to OSM gives only one day’s data on the design date.
Is there a way to get time series data for the entire analysis period?
Can “write to Excel” do that?
If you can do it, please let me know how.
Hi @nano
The read room energy give you data for each hour in the analyse period.
You can use the deconstruct data from ladybug to separate the header from the hourly data
nano
December 23, 2023, 11:18am
3
Hi @Erikbeeren
Thanks for the reply!
Is it possible to check that data in Excel?
@nano ,
Yes I use TTToolbox for this.
writing data to excel.gh (16.1 KB)
nano
December 23, 2023, 12:01pm
5
Hi @Erikbeeren
It has already been downloaded.
However, I can’t figure out how to use it from the description.
I can understand earlier versions but not newer ones.
If you don’t mind, could you give me detailed instructions on how to use it?
I have no idea where to connect anything.
@nano
you can also use the old one. But if you set display "draw full names"it will tell you more.
nano
December 23, 2023, 3:19pm
7
Hi @Erikbeeren
Thanks for letting me know.
I’ll give it a try!
nano
December 24, 2023, 8:39am
8
I was able to confirm this in Excel.
However, there is a slight difference between the Excel data and the numbers that can be checked in the simulation.
Do you know the cause of this?
