Hello
I need to calculate the thermal comfort inside a building in a project. Since the building is assumed to be without air conditioning, I use Adaptive Comfort to calculate the indoor operative temperature. In the process of the project, I need to know the deviation from the comfort temperature so that I can also calculate the amount of departure from the comfort range.
In this way, the question that came to me about the difference in operative temperature output from the component
HB Read Room Comfort Result with Operative temperature is output from LB Adaptive Chart component, which are very different from each other. I don’t know which is the correct measurement criterion to choose for the optimization process of different project alternatives and I’m a little confused.
It also shows the number of hours outside the comfort range and operative temperature with the LB Adaptive Chart component. Can I get an output in the form of a numerical interval of minimum and maximum deviation from the comfort temperature?
Please help me to do a correct simulation ![]()
