Hi there,
Question is as stated in the title.
Wanting to be able to add ep_construction to HB apertures by ratio component.
Is this possible?
cheers
Hi there,
Is this possible?
cheers
You can do that with two options (is not related to the Apertures by ratio):
ApplyWindowConstr component for a specific window construction).-A.
FYI, here’s the documentation for the second component that Abraham mentioned, which is arguably the faster way to do this.
