Add Internal Mass to Zone component error
HI
What is the cause of error?
i’ll appreciate you if helping me.
thanks a lot
Sepideh
  1. Can you share your definition?
  2. In case you can’t share the definition connect a panel to out and copy the full error report.
I sent the file to you.
check to see what is the cause of the Error ,please?
In the past days, I had a problem with this file and uploaded Error in the forum. but I could not solve the problem.:point_down:
Hi @sepideh7
Sometimes this error comes without any real cause … you just need to remove the internal mass component and drag a new one and again connect the brep to it …
HI
The previous problem was solved, thanks for your guidness.
but there are two Error now
.I changed the panel name but it did not work
For your first error, there is a duplicate zone name as “zoneplenum” … it means you used the same name for more than one zone … you have to assign different name for each zone …
your second error seems because of the output of the simulation … check if there is any output from air temperature result …
Finally you have to update your plugins … its too old …
Regards
Amir
