Adding triangle extention to the facade
Hello all,
I’'m trying to add a triangle extension to the façade as you can see in the attached picture. I want to change the angle α while keeping the length of the (A) side fix but (B) side can change to accommodate the changes in the angle α. I don’t know how to do that so I would be really thankful if you can help me.
Thanks in advance.
facade (triangle).gh (964.6 KB)
facade (triangle).3dm (60.4 KB)
This is not a Ladybug Tools specific question and you might have a better chance to get a reply if you post it to Mcneel forum:
Here is how you can do it:
  1. Explode window face and find the top edge.
  2. Use EvaluateFace component to find the normal vector of your face.
  3. Rotate the normal vector by the angle that you need and use the edge as the axis for rotation.
  4. Move the edge for a distance of A and in the direction of vector that is created in step 3.
  5. Loft original edge with the moved one. Don’t forget to flatten the input.
