Adding Volumetric heat source in reactingFoam
How can i create a volumetric heat source as spherical ignition source at the centre of a cube filled with CH4/air mixture in OpenFOAM? All helps are much appreciated. Thank you
This topic might be helpful.
Note that the first line of a OpenFOAM file starts with /*-, not /--.
