Additional Radiance Parameters
Hallo guys,
hallo sir Mostapha,
I wanted to ask if it was possible to set/modify in honeybee these radiance parameters (see the Picture), to change the accuracy of the daylight factor result.
RadPar-NiedrigeGenauigkeit
Thanks in Advance, best Regards
@gaetano.christian.ruvio You can use Honeybee RADParameters component to set advance parameters. And If you can’t find the some parameter, you can use additionalP for input.
Thank you very much, your help has been precious!!
Best regards
