I am modelling a floor plan parametrically in order to investigate it with fly but having problems solving adjacency. Three parametric surfaces are extruded and fed in a room from solid component then adjacency is solved. When the floor plan is square it works but when the floor plan is shaped as as H or U there are still windows present on the interior walls. Is the solve adjacency component unable to resolve surfaces that are partly internal and partly external walls? is there a way around this or do i need to model additional surfaces so that the vertical surfaces are cleanly separated in to fully internal or fully external?
