Air to water heat pump with baseboard water heating radiator Ironbug
Hi! I’m trying to perform simulations of an air to water heat pump, where the only heating equipment are water radiators. I think I may be connecting the demand branches unproperly, since I get a warning about names and maybe that’s the cause of a fatal error? I was advised before by @MingboPeng to use this HVAC template, but since there is no cooling in the building that I’m working with, I have deleted the chilled water loop (I’m guessing this fact doesn’t mess the flow of information? Or I still need to simulate that loop?)
Hi @MGawel
All you need is zipped in the below playlist in Youtube
Thank you! I found the missing component there.
