AirWalls E+ and Daylight Analysis (and InternalMass problem?)
I am trying to create a house/unit with a semi-basement and an attic floor. I created (or tried to) Air Walls between the “basement” zone and the “1st floor zone” and between the “3rd floor zone” and the “Attic floor” as I named them. I then assign materials, schedules, properties etc but from the analyses I understand that the Air Walls are not considered Air walls but normal ceilings/floors. To double check I ran a Daylight analysis on the “basement’s” surface to examine if I had any daylight. Unfortunately answer is none. I also check my E+ which also showed that there is no Air Walls in the analysis. I went through all available tuttorials and discussions and followed what is in the example files. Profoundly is something that I am missing and due to overtime (I am modelling 47 of them with different geometries) I cannot see.
I am attaching my gh definition in case someone can have a look and check what am I doing wrong or reading wrong or using wrong in there!
Finally I am trying to use the **HB_Add InternalMass to Zone **component which needs to be re-instantiated every time I open my definition, else is giving a warning or error!
Thanks in advance!
Tasos
AIRWALL_Construction_EP&RADanalysis.gh (762 KB)
Hi Tasos,
I’m not going to be very helpful here but … you just have a lot of work to do to make it work right. Right now the file is pretty messy.
You need to work at HB_Surface label, rather than full zones in order to assign the constructions you want to the proper geometry. Hope this is clear to you.
The daylighting is not showing you what you want to see becouse it is not supposed to do so. The EP materials you assign are for (of course) E+ and not for Radiance. So if you don’t see “the light” it doeasn’t mean in this case, that the definitions are right or wrong for E+ (in this case they are wrong).
Sorry for this but there is so much work to do here that i don’t have the time to be more helpful.
Hi Abraham,
Thank you for your reply. I think assigning the right material or not is not influencing the daylight analysis basic results. Does it? For the basement I am trying to get results for, the daylight penetration is 0 for any given height till I reach the defined “Air Wall” I tried to create. Once I exceed this height I get results back as expected and I follow step by step the examples for Air Wall definition that Chris has provided. Please if you do find the time to indicate the mistake on my definition I would be grateful! In any case thank you for the input!
I am attaching again the gh definition and two screenshots. The first is the Daylight analysis for 1.45m offset from the basement level (so 5 cm under the defined “Air Wall”) and the second is the same analysis for 1.55m offset from the basement level (so 5cm over the defined “Air Wall”). I think is obvious that the “Air Wall” is not considered as an “Air Wall” but as a normal geometry!
Best
Tasos
Hi Tasos,
What i’m saying is that the AirWall E+ material definition is not good for radiance simulations (in this case your daylight tests). For this, you need to define RADMaterials. But this is not going to help anyway becouse those are two different definitions. In this sense your figures are misleading you, even though the conclusion is correct.
From what i checked this morning you are assigning the same E+ materials (or constructions) to all the surfaces (walls, floors, etc). So that’s why in my opinion you need to decompose the zones in their surfaces to enable the assignment of different materials.
I don’t know how much time you have to get this done, but if you have some, i would start with a simple case of, maybe, two floors (zones), where you can be sure the materials assignment is what you expect the to be.
Just a quick comment until I find some time to take a closer look to your file. Honeybee assigns AIRWALL only to walls. It was intentional not to let user set all adjacent surfaces to airwalls by mistake.
-Mostapha
Tasos,
You bring up an important issue that needed to be changed since the addition of air walls in the last release. Mostapha had originally put in an option to “removeInteriorWalls” on the daylighting simulation component to help in cases where interior walls were just for the partitioning of thermal zones and not meant to be real solid walls.
In full implementation of air walls in the last release, I only changed how air walls worked for thermal simulations and did not change anything with regards to daylighting. I have just changed this “removeInteriorWalls” on the daylighting simulation component to be “removeAirWalls” and I have set the default to remove air wall surfaces (you can change this by setting “removeAirWalls” to True).
If you sync with the github, you will be able to get the new daylighting simulation component that does this.
As for the Add InternalMass to Zone component, I am afraid that I do not understand the problem. What is the warning message that you are getting each time?
-Chris
Thanks a lot for your replies! I tried the new Components! They now seem to work fine. The “Solve Adjacencies” component assigns Air Wall to both Walls and Floors now (which I think would be great to have as an option with the assignment of an integer as input, for example: “1” : Remove/assign to Horizontal surfaces “2” : Remove /assign to Vertical surfaces “3” : Remove/assign to both or something similar). As for the Daylight component, indeed you can now “exportAirWalls” or not, is this right Chris? Or you meant another component? In any case if I set this to False I get the expected results! Also there, a small note, the default is set to True although at the description says that the default is set to False. Non-sense detail but I just noticed!
Finally for the “Add InternalMass” component the error I am getting whenever I re-open the gh file is that the Index is out of range which probably implies that the component keeps the information of the surfaces stored even if you run it again or something similar? And the warning I get is that some geometries are not Completely inside the zones which is also fixed once I drag n drop a new component on the canvas (for this one I am really puzzled!)! in Any case a new component solves both issues but still!
Last question probably not for this topic but very close. If I set the “IsCondintioned” from the Building2Masses component to True and then I set my conditions manually for each zone, is it overwritten or not? Or I should keep it to False and then assign condition my zones?
Thanks again for all your input!
Tasos
Tasos,
I’m glad the components are working well for you.
You can set the walls to air walls and the floors/ceilings to be a different construction by using two solve adjacencies components in tandem and a “separateByFloor” component like so:
I prefer this method since it seems to be more in the spirit of grasshopper component-based workflows and allows you to change the constructions of the floors/ceilings with the second solve adjacency component.
Thanks for finding the bug in the default ExportAirWalls. I just uploaded a fixed version to the github.
The warning that the “Add Internal Mass” component is giving you is telling you that you should make sure that each of your individual surfaces lies completely inside a zone. If a surface spans between two or more zones, the component doesn’t know which zone to assign the surface to. The component is not copying anything to memory or storing any information. What might be happening is, if you are changing the tolerance of your Rhino model or have internalized geometry created with a different Rhino model tolerance, the function that calculates whether the surfaces are inside a zone does not use the right tolerance. I also know that this “surface inside brep” function was apparently buggy on McNeel’s end and that I should re-write this function soon. If you upload your file with the issue, I will try to improve it.
I am not sure which components you are using but the “IsConditioned” will be overwritten by a more downstream component that has the “IsConditioned” input.
-Chris
Hello
I have a similar case to Tasos, and I want to know what is the best way to model Air Wall for daylighting simulation. Is the best way to assign a glass with 100% transmittance to those special walls?
What is the most efficient way to select those air walls (which do not exist and I used them to separate thermal zones) in a model with multiple zones? I have just created one floor and my goal is to create 6 floors finally.
Thanks for your help
Ladan
CCC_Honeybee_Gridbased_22_11_16.gh (590 KB)
If the construction is set to AIR WALL then just set exportAirWalls_ input in daylighting component to False not to export them to Radiance.
Mostapha,
Would you please also tell me how I can pick interior surfaces and change them to airwalls? No all my interior surfaces are airwalls and I don’t know what is the efficient way to find those walls?
Thanks
Ladan
Hi Ladan,
I believe you already know who to select those walls that you want to turn into interior walls. Once you do that, you can use Honeybee_createHBSrfs to turn it into an airwall. The resulting HBSurface will have to be connected to Honeybee_createHBZones component eventually.
Devang
Thank you I’ll try that and let you know if I had any further issues. I appreciate your help.
Ladan
Why don’t you just use findAdjacency component to set up the construction for all the interior walls? It will automatically find adjacent surfaces and set them as Air Walls.
Hello all
I created “select items” and picked the spaces with air walls and assigned “AIR WALL” material to them. Now my air walls and interior walls are correct and I checked the labels. However, there are other issues with my file now:
  1. first, I want to ask if the way that I did this task was the most efficient way. Because it took me around 2-3 hours to assign spaces with air walls and separate them from other spaces and find interior walls. I had one floor plan with 31 spaces.
  2. Since I fixed my air walls and interior walls by using Find Adjacency, my file crashes and freezes and it is not operating well. i could not run a Grid Based DL simulation because it crashed all the time.
  3. One thing that I did different from Chris’s E+ tutorial was that I added glazing before finding adjacencies. Please tell me if that is the reason that my file is crashing.
Chris, Mostapha, and HB group members, would you please look at my file and tell me if I am mistaken? My final target is to apply “integrated daylighting and energy simulation” to my floor plan. Now, I am concluding that it is very hard to do that when you have multiple zones. Please tell me if I am wrong.
Thanks for your help. I really appreciate your support.
ladan
  1. You can/should use “split list” component to split the components between the two.
  2. Just from the screen capture looks like you’re not in control of the data flow. I suggest you to flatten the output of modified honeybee objects and also change the materials after adding the openings. Have you already intersected the walls and split them into smaller portions before solving adjacencies?
  3. If you are adding the windows to particular faces which are not interior then the order won’t make a difference.
Let me put a simple example together for 3 room which I hope answer most of your questions.
