Hello Everybody,
i have some problems with my daylight simulation.
I want to modify my radParameters, but if i set ambient accuracy to zero every testPoints value becomes zero. Normaly there should be still a higher amount of light than zero if i am not wrong.
This only happens when I use glass surfaces. If I leave the areas blank, I get normal results.
I hope you have any answer to this question.
I registered myself today and for this reason I can not upload anything yet.
Thanks in advance
We need more details to be able to help you. Are you using honeybee or honeybee[+]? Which daylight recipe are you using in this case? Did you get any errors?
Attached you will find the file which has both variants
ambient_accuracy_problem.gh (540.1 KB)
I am using honeybee with the daylight factor simulation and get no errors.
Do you think honeybee [+] could work in a more proper way?
I didn’t try it yet.
Hi @GreenCape
When you set -aa to 0, Radiance turns off ambient caching. This dramatically changes the way Radiance performs the calculations, as a consequence, you need to change a couple of other parameters to get accurate results. One of the most important setting is -lw. When you set -aa to 0, always make sure that -lw is to a very small number (such as 1e-6). You can do it in your definition in honeybee like shown in the image below:
This should fix your problem.
Good luck!
Hamza
Hi MohammadHamza,
thank you for your answer.
It solves my problem!
Is there a good composition for the respective parameters and how they react to each other?
It is very important for me to understand all the parameters to make a meaningful calculation.
Thank you in advance
