I’m trying to analysis the effect of shader’s angle on a room’s daylight quality. but there is an error on “Run Daylight Simulation” component ~~> 1. Solution exception:Illegal characters in path. i don’t know what is the issue!
Thank you so much, it works… but still i have a problem which by changing the angle of shaders, the results of UDI doesn’t change. running shader and changing the angle have no effect on the results.
Hi,mahr
I am in trouble in the issue like you . The blind angle is not have effect to the result . So have you addressed it .
Could you tell me how to correct it.
