Hi Mostapha et al.
I am teaching myself by following tutorial provided by Mostapha.
The first example file, an outdoor airflow was working great as shown in attached image.
But I duplicated an vertical test Geometry and moved it in the different X-direction. The first one was moved by 10 cm from the original location, but showed totally different result. No color variation. I don’t think 10cm translation can generate that dramatic change.
The second one was moved to the middle of small building, but the same issue with the first. No color variation.
Any clue?
I appreciate your input in advance.
