Is there a way to display the result from a Ladybug analysis over time so that the output in Rhino is like an animation show how, for example, the radiation on the walls change over time? I’m thinking of a step component which will feed data to the script in hourly steps so that the results are displayed on the Rhino model like an animation.
Yes. Search the forum for fly
or colibri
For simple cases with a single slider you can also animate a grasshopper slider.
Is there a previous thread where I can find out more about how to animate a slider?
Hi,@Mackie Animated slider is a common function of Grasshooper. You can refer to some video on Youtube channel.
Here are 2 example video.
