Annual Cooling and Heating Loads Are Much Higher Than Expected for a Single Office Model
Hello everyone,
I am an undergraduate student from South Korea conducting my graduation research using Honeybee and Ladybug Tools. I would really appreciate any advice.
I am simulating a single office space inside an office building. The model represents only one office room, not the entire building.
My model setup is as follows:
  • Honeybee / Ladybug Tools 1.10
  • EnergyPlus annual simulation
  • Seoul EPW weather file
  • South façade: curtain wall (window)
  • North, east, west walls, roof, and floor are all set to Adiabatic because I assume there is no heat transfer to adjacent spaces.
  • Ideal Air Loads HVAC
  • Office Program with modified schedules
  • Cooling and heating schedules are from 9:00 AM to 6:00 PM on weekdays.
  • Annual Loads is used to calculate the cooling and heating loads.
However, the annual cooling and heating loads are much higher than I expected.
I have already checked or modified the following:
  • Construction Set
  • Window properties (SHGC, U-value)
  • Internal loads (People, Lighting, Equipment)
  • Cooling and heating setpoints
  • Ventilation and infiltration
  • Natural ventilation settings
  • Adiabatic boundary conditions
Despite these changes, the cooling load remains much higher than expected.
Since this is only a single office room, I expected the annual cooling and heating loads to be much lower.
Could anyone help me identify what I might be doing wrong, or suggest what else I should check?
Thank you very much for your time and help.
바나나킥.gh (587.7 KB)
It would be nice to give specific numbers rather than “much higher than expected”, so we can try to help you :slight_smile:
The expected values are that the annual cooling load and the annual heating load are 1–8 kWh/m²…
I am a Korean student, but there is no one around me who can help. I want to know what the problem is in my algorithm configuration or data settings.
