I am trying to run an annual daylight analysis but there only is one value as an output. I opened the example file from ladybug and there was the same mistake so I guess there must be a mistake in the settings somewhere.
Does anyone how to fix this ?
Thanks in advance
I should have been able to help if you would have shared the sample file. See here: Ladybug Tools Forum Guidelines - faq - Ladybug Tools | Forum
