i trying to conduct standard annual daylight analysis, but i’m getting an error as below.
- Solution exception:a479823c-2d26-4a62-baa7-6c3ae12ee768
I can’t seem to find what have i done is wrong.
Annual_Daylight_Simulation_Template.3dm (76.6 KB) Annual_Daylight_Simulation_Template.gh (542.4 KB)
can someone please help?
Add Glazing by creating a glazing surface on the wall (do not create a puncture on the wall to add a new glazing surface) .
please check this file
Annual_Daylight_Simulation_Template.gh (554.1 KB) Annual_Daylight_Simulation_Template.3dm (112.5 KB)
Hi Teja,
It did work indeed. Many thanks.
Can I please ask few queries based on it?
- You have isolated all building elements instead of using HBZones. If I use HB zone (my original definition) it does not work, gives another error. So when & how do we use HBZones?
- It seems like the Simulation in your definition has ignored the sky-light, even though it does not show any errors. Why would that happen?
if you could find some time to respond, it will be very helpful.
Regards,
Agneesh
try using honeybee plus components for simulating the skylight.
Thnx a lot Teja.
How do i get HoneyBee Plus? i do not have all HBPlus components. i have latest 2020 HB components.
food4rhino and you can refer to this
post
