Annual Daylight Analysis, Spatial Daylight Autonomy
Hi Lisa,
I’m not sure about this script but if you’re doing an sDA for LEEDv4 then take care that DA and sDA are not the same.
The sDA is the same as a DA that uses a special schedule for the glare controls. If this is not setup then your sDA is wrong (and actually just a DA)
No matter how the output of @mostapha s component is described :slight_smile:
