Annual daylight error when simulation
I get this error, when I try to run my annual daylight simulation.
I cant seem to figure out, how to find a solution. Can someone help me?
I cannot upload my script, so please reach out to me, if you can help. Then i can send my script.
Thanks a lot,
Kind Regards,
Frederikke
Hi @Fm,
Reading the error message there’s an issue with your Radiance installation.
I’d recommend deleting your Radiance folder in your C: drive location and if that doesn’t fix it also running the Pollination Grasshopper one click installer.
Hope that helps!
Cheers,
Charlie
Thanks, So I have to delete it compliantly? I will tray that :slight_smile:
Yes delete the whole folder, hopefully it helps
Hi agian,
Now I get this error:
Do you know the solution to this?
Kind regards,
Frederikke
Next step try running the pollination one click installer :slight_smile:
It’s the most robust way of getting ladybug tools fully working (although no method is perfect!)
Oops,What should I do? :dizzy_face:
