I updated the ladybug tools yesterday to version 1.5.44.
I am testing annual daylight analysis on a project that I ran earlier on 1.5.32 which ran successfully.
Please find below the log for the successful run successfullogs.log (662.2 KB)
When I run it after updating, I get the following error.
Thanks for sharing the file in a PM. I did run it successfully. However, I just noticed that the lines in the top of your image (line 117, 93) tells me that you did not get the latest updates in your core libraries. I pushed a fix 3 days ago to avoid the error you are facing. Can you try run LB Versioner again?
