Hello! I have the following problem with the HB Annual daylight recipe while I am working with Ladybug Tools v. 1.6.0 . It seems that the task of sunpath generation fails. Specifically I am getting this error. Here by there are some printscreens with the report.
- Solution exception:The recipe failed to run with the following summary:
Scheduled 11 tasks of which:
- 4 ran successfully:
- 1 CreateDirectSky(…)
- 1 CreateRadFolder(…)
- 1 CreateSkyDome(…)
- 1 CreateTotalSky(…)
- 1 failed:
- 1 GenerateSunpath(…)
- 6 were left pending, among these:
- 6 had failed dependencies:
- 1 CalculateAnnualMetrics(…)
- 1 CalculateTwoPhaseMatrix(…)
- 1 LetAnnualDaylightFly(…)
- 1 ParseSunUpHours(…)
- 1 PrepareMultiphase(…)
This progress looks because there were failed tasks
Traceback:
line 139,in script
I have tried to uninstall and install again the LB suite but it did not work.
Moreover, I have installation problems with Radiance and Openstudio. Even if I install them in the folder of [ladybug_tools] with the file path as recommended in GitHub, the GH components do not recognise it. Should I install them at the C: drive instead? Here by there are printscreens with the problem:
Note: I did not have the same problems when I used version 1.2.0
Thank you.
