I am hoping someone could help me with this issue.
When I run annual simulation, I get the following error message from the “readAnnualResultsl”;
Can’t sort .ill files based on the file names. Make sure branches are sorted correctly. 1. Solution exception:Could not find a part of the path ‘C:\Ladybug\Annual\annualSimulation’.
It looks like “runDaylightAnalysis” component is not generating .ill files in the folder. But “runDaylightAnalysis” is not outputting any error message.
When I run it, command screen wizzes through so I don’t think it’s running annual simulation at all. Am I putting in wrong settings for Daysim / Radiance?
Try to run the analysis again (False & True or close and open GH file ). It seems that wire detached\disconnected from the output and the output data was removed.
Moreover, you can use Honeybee_**Lookup Daylighting Folder. **
