I’m working on Annual Daylight analys. I have a question about this.
Every time I open the Grasshopper program, the numerical analysis values in Xdata change. I couldn’t understand why. I would be glad if you help.
You can see the changing values when I open the same file from the images I added.
When I first open the program, the value in the Xdata value section for the 8th hour of the day is 1.361678. When I close the program and reopen it, this value becomes 0.69221. I don’t understand why the values are changing.
