Annual DGP simulation error in H+
Do you have one of the files open already? If you don’t want to close the files then you can change the folder.
The result will be 4015 images which you should run through evalglare one by one for glare analysis. I would use fly to automate the process. Passing 4000 images to any component including Image_viewer can make the process very slow and you don’t really need it.
