Annual loads error. Value error exception: No JSON object could be decoded after update to LBT 1.8.0
I’m currently running in to this error trying to get annual loads for a multi room model. After reading through the forum i have updated openstudio to 3.7.0 and LBT to 1.8.0 to try to fix the bug. The analysis works fine on the rooms individually but the error is raised when i connect the solve adjacencies component to run the whole model with internal walls etc.
