Annual loads reporting lighting, equipment, heating and cooling twice
I’m getting weird results with my annual loads. it has doubled all inputs in one of the graphs
Apartment energy (1).gh (580.3 KB)
Hi @Nicholaskerr,
It appears that your shading geometry is coming in to the Annual Loads component on two separate paths: {0} and {0:0}. This causes the component to run twice, which results in the double output results.
The normal Annual Loads component has a ‘flatten’ modifier on the ‘_shade’ input node to avoid exactly this situation. For some reason the Annual Loads component in your scene has had this ‘flatten’ turned off/removed. If you right click on the ‘_shade’ node, and re-apply the ‘flatten’, it should work as you expect.
best,
@edpmay
Fantastic, thank you @edpmay
