I know it sounds silly, but I am currently working on a small passive pavilion project, so it has no mechanical HAVC system. What I am trying to analyze is the DB Temperature differences between inside the pavilion and outside, and generated a visualized map.
So the question is which component I should work with to visualized the temperature differences? I tried HB-indoorAirTemMap component but it only provided a solid color distribution at floor plate level (attached). How can I get the indoorAirTemMap and OutdoorAirTemMap at the same time to see the passive strategies performance?
HB-in vs out.gh (531 KB)
