Aperture FaceType colored as "N/A"
Hi there!
I have created a model and I’ve noticed that the component “HB Color Face Attributes” does not color the apertures as “Apertures”. It labels them as “N/A”, although it seems that the apertures have been well set. Walls, Roof Ceilings and Floors seem to work OK.
I am using 1.1.1 version for this Color component. Any ideas of what is causing this issue?
Thanks you all in advance,
Carles
Try checking with the VizByType or the FacesByType components.
Hi @AbrahamYezioro , thanks for the quick response.
The components you suggest run perfectly, as I can see the apertures. The thing I was wondering is if there was any problem with my model or the problem is related with the “HB Color” component.
Carles
There’s nothing wrong with your model.
You get a N/A because Apertures don’t have a Face Type property. Only Faces have a Face type. So the Face Type property is not applicable to Apertures.
