Aperture Groups LT 1.7.0
Hi everyone,
I’ve just installed LT 1.7.0 (looks great btw) and I’m trying to use the dynamic apertures. The sample file dynamic_apertures.gh works fine, but in my own model I have the following problem:
When the Aperture output is connected directly to the AddSubface component, everything works fine, however when it is first connected to the ApertureGroup component, and its output to AddSubface, I get incredibly low illuminance values.
This is before I add other dynamic states or different groups for different facades… I get the problem as soon as I introduce the ApertureGroup component. See the image below - in the current state things work, but when group_aps is connected instead, I get very low illuminance.
Any suggestions?
Without ApertureGroup (ignore red dot - just a sensor):
With ApertureGroup:
Hi @jroberts,
Did you by any chance connect the output of both Aperture and ApertureGroup to AddSubface? If not please share your file here or in a PM if possible.
Hi @mikkel,
No, they’re not both connected. I’ve recreated the problem with a very simple geometry and noticed two things:
  • When the ApertureGroup component is used AND enhanced_ is set to FALSE in the AnnualDaylight Recipe, I get a result but only of the default aperture state with the error message “No dynamic aperture groups were found in the Model. The input dynamic schedules will be ignored.
  • When the ApertureGroup component is used AND enhanced_ is set to TRUE in the AnnualDaylight Recipe, I get 0% DA all over my grid, regardless of the chosen state:
Please see the attached file
DynamicAperturesError.gh (80.4 KB)
Thank you!
Joe
Thank you, @jroberts!
This is expected. You have to use the enhanced in order to run a simulation for all the different states. If set to False it will still run, but only for the default state.
The sensor grids have a property called room_identifier. In order to link the aperture group to the grid, the room_identifier of the grid must be the same as the identifier. If you use HB Sensor Grid from Rooms the room_identifier is automatically set. If you create the grid manually, you can set the property yourself. This should be fine as long as you match the grids and rooms correctly. I have attached the example in the file.
DynamicAperturesError.gh (90.5 KB)
Hi @mikkel,
Thanks for the great workaround!
The reason I was manually generating the grid was because I was having trouble with the GridRooms component, but I think I’ve worked out now what the problem was (I hadn’t seen the _type_ input and it was confusing the ceiling with the floor). I will carry on with the sensor grid from rooms, rather than doing it manually, but it’s always good to learn a bit more about what LBT is doing underneath the hood.
Thanks again,
Joe
