Good afternoon, Im writting this lines because I have a problem with shading mask. Im creating a model in grassopher like the solar tools of ecotect. When I create the room, the hole for the windows and the cantilever its ok.
The problem is when I create a brise soleil with array. The shading mask suddenly only show the shading of the brise soleil, and doesnt show the shading of the rest of the model. I attach the grasshopper file. Its quite disorder because its the first time I model in grasshopper.
I suggest to send a minimal, simple working version of the file.
Hi Abraham, I have upload a new versión simplified, just a rectangle and a array. I have the same problem with this very simplify model, so it´s not possible the high number of surfaces.
Thanks
Pregunta sombra.gh (44.6 KB)
Well, you just need to flatten the context input for this to work.
Also attached a real simplified version of the file (just what is needed) for the case.
Notice that you were missing the LB_LB component.
Pregunta sombra_AY.gh (385.7 KB)
