Artificial Lighting simulation
I would like to study the artificial lighting in a standard room according to the power of the lights and their location but I can’t find simple tutorials with my working version: version 1.4.3.
I would like to have the result in lux.
I already tried with old tutorials but it’s blocked.
Is there someone who has already tried to do this study and could help me?
Thanks in advance for your help.
@angeline_christine Ladybug tools version 1.4.3 does not support artifical lighting simulation. You can use Ladybug legacy version which support artifical lighting simulation.
Here is some example created by @sarith .
http://hydrashare.github.io/hydra/viewer?owner=sariths&fork=hydra&id=IES_Electric_Lighting_Grid-based_calculations&slide=0&scale=1&offset=0,0
http://hydrashare.github.io/hydra/viewer?owner=sariths&fork=hydra&id=IES_Electric_Lighting_Basic_Example&slide=0&scale=1&offset=0,0
Ok, I will try with ladybug legacy
Thank you very much !!
Hello Minggangyin, do I just need to download the Legacy installer, and it will work fine on my Rhino 8 with the latest LBT package?
The example I posted is the whole workflow of artifical lighting simultion.
As I know, ladybug honeybee legacy does not work fine on Rhino8, please user Rhino insteadl.
Co-work with Ladybug tools new version, you can use model to rad folder for reusing the exist model.
