ASE component - zero hours
Hi @giorgio_butturini, 3-Phase doesn’t have a separate calculation for direct sun contribution and that’s why you get all 0s. You should use Daylight Coefficient or 5-Phase recipes for this case. They both calculate the direct sun radiation and hence can be used for ASE calculation.
We should add a proper error message for using 3Phase for calculating ASE instead of returning 0s.
