Hi everyone! As you can see, when I try the 3-phase simulation, the component would go wrong and says:Solution exception:AssertionError. I do not know what is going on here. My ladybug and honeybee tools are both 1.7 version. The Honeybee Plus is 0.0.06 version.
Hi -
You’re only showing a small part of that Grasshopper definition, so it’s impossible to tell what’s going on based on just that. You mention LBT 1.7 and Honeybee Plus 0.0.06, though. Generally, components from those two different components can’t be used together! You should probably state why you are still using the legacy 0.0.06 version.
-wim
